Natural/Propane gas
Jack Kagan
Member Posts: 9
Replacing an old borken oil boiler with a gas boiler, but utiltity can't run gas inot house for at least 8 weeks. Can a gas-fired heating hot water boiler run on natural gas and/or propane without any major changes or adjustments?
Most can
Most boilers can be converted fairly easily. A tech should do the conversion (usually a regulator adjustment and a different orifice) and check combustion. There are a few boilers (Triangle Tube Prestige 110 is one) that flat out cannot be converted. Be sure to check with the manufacture."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Two diff...
animals.... most boilers can be converted one way to another. Some require more work that others. We are getting out of heating season.... You could get the boiler piped and ready to go w/ Nat gas and temporarily put an electric in for 2 months....0 -
Viessmann Vitodens 200
is a duel fuel boiler that allegedly requires no adjustments when going between natural gas and LP. I've not personally run it that way, but have a good friend who has. He said it switched right over, no problem.
Most other boilers, as has been noted, can be run on either fuel with slight modifications. You MUST check the fire side with a combustion analyzer when going one way or the other.
ME0 -
Jack Kagan
Thank you for the information.0 -
Jack Kagan
Do you mean install an electric boiler until I get gas?0 -
Jack Kaganjkagan
Thank you, I will check it out.0 -
Nat/LP
Zman I just had a Heating contractor ask me this question today. I am the wholesaler and I called Triangle Tube tech and they told me the PS110 LP can be converted to nat gas there is a kit for it.0 -
water heater....
not a boiler. The LP company will stick it to you if they only have a few months of LP being used. Its in the summer.... you don't need heat....just use a 40 electric for your hot water needs until you have the whole system ready. I do this all the time for my customers as a courtesy.0 -
Jack Kagan
Got it. Thanks again.0 -
PS110 gas changeover
Is different than the rest of the line - requires a new burner head. Order the PSRKIT10 for NG or the PSRKIT11 for LPG.0 -
Conversions:
Veissmann Vitodens only require you add a disk to the gas valve and temm the brain that it is LP. To convert back, you remove the disk and tell the brain you did it.0 -
Lambda control
Is great stuff.
Best I've seen so far is in the Rational combi ovens (another German masterpiece.) Burns anything from low BTU landfill gas to LPG at any altitude from sea level to 15k feet with only software changes. Wish we had boilers like that!0 -
Vitodens 200
Not only will it convert without you telling it (you should anyway), but it will automatically adjust on Nat Gas to 4" and adjust the A/F ratio automatically and give you the proper output. If the pressure is less than .4, it still runs properly, it just doesn't give you the rated output.
As I remember it from the Veissmann School I did last year.0 -
TT 110
If I recall the propane model can go to gas. It stays derated the same as the propane. The gas model cannot go to propane. It has to do with the mesh material of the sock on the burner. This was true of the previous model. They may have changed it with the new version"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
munchkin
I didn't get the job, but at one point I got a call to change over a Munchkin from natural to LP (the person was moving from the city to the country and wanted to bring their boiler with them). When I called HTP about converting the Munchie, I'm pretty sure they told me that only adjustments to the gas pressure and a combustion analysis be done and they would send a new data plate to show the conversion. (Dungs gas valve).
Rob0 -
those kits
include the new burner screen0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
