one pipe two connections to radiator
jumper
Member Posts: 2,541
On this site is a picture of a Wilson fitting.
I think that I remember a building in which radiators were connected this way.
One pipe from floor went up beside radiator to connect at both top & bottom.
Is my memory incorrect ? Could you eliminate the rad vent this way ?
no, you would still need the vent
as the air in the radiator still has to be able to escape to atmosphere..gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 120 Geothermal
