Radiant floor with domestic h20
Vito200
I have a room with under floor radiant that will be connecting off of a domestic tank, i am going to use a 2 circuit manifold. Any decent piping diagrams would be helpful.
don't do it....
plain and simple. You are contaminating your water supply and risk harming your heath.... Use a separate heating set up.0 -
This is a Vertex with seperate hydronic tappings0 -
They are not made for radiant heating
they are made to go to an air handler with a round trip of less than 50 feet total. Radiant heat is a breeding ground for bacteria and should only be connected through a heat exchanger to this unit.Cost is what you spend , value is what you get.
cell # 413-841-6726
Closed?
Unless the heater has a "closed" hydronic coil. Don't do it. Just because some manufactures are enabling people to put in unsafe systems, it is still the wrong way to do it."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
ditto
Ditto.0 -
Radiant h20
I am using a plate heat exchanger , any piping diagrams?0 -
Personal preference
There are quite a few ways to do this. How much detail are you looking for? You need to pump from the hot water heater in the exchanger. My plan for the other side would be to use a variable speed pump controlled by a tekmar 356 with outdoor reset to in inject the water into the radiant loop from the exchanger. This way you can control the floor temps and avoid dragging down the hotwater temp using the boiler protection feature on the controller. You will of course need air eliminators,zone valves, pumps ect. to control the radiant side."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Taco x block
Just used the taco x block on two separate installs here in the city ,4 units of a condo complex I found with open systems,worked beautifully simplified piping in a tight spot.still trying to convince other two owners to change theirs or at the least not used it as is.0 -
I 2nd..
the X-block. A sinple all in one design ... air seperation, HX, and control. They have nice diagrams. http://s3.pexsupply.com/manuals/1326240192388/70252_PROD_FILE.pdf0 -
Good Call looks like the best approach using the Taco x block
Thanks0 -
X block
I have used the X block on a water heater to go to just a bath floor with outdoor reset and no t-stat and it works great0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
