trouble understanding 1 of dans p/s theorys
stev0
Member Posts: 11
hi, begining plumber just getting into hydronics .in book pumping away pg96 dan said make your takoofs to the zones from the bottom instead of from the top of the manifold.cant picture that unless manifold was pointing down like a pitchfork ? thanks for any info
Think of.......
...... a bubble in the pipe , where would it end up ?There was an error rendering this rich post.
Ghost Flow
I'm not looking at the book at the moment, but he's probably referring to making a heat trap to prevent ghost flow.Bob Boan
Yep.
That's the reason. Courtesy of the late, great Gil Carlson.Retired and loving it.0
- 167 Indoor-Air Quality
