flow check valve and swing check valve
heatingFun
Member Posts: 84
what's the difference between the flow check valve and swing check valve?
I need a flow check valve for a separate zone but the Lowes guy told me I could use swing check valve for that purpose. Is that true?
Is that true?
I think the guy working at Lowes is working there because he does not know enogh to be a heating and plumbing professional. A swing check valve might be enougb to prevent back flow in a multi-zone hydronic heating system, but it would do nothing to prevent ghost flow (forward flow, thermal convection flow). For that you need a real flow check valve.0 -
Lowes
I don't think I have had a conversation that started with "the guy from lowes said..."that ended well. As the previous poster mentioned they are not the same. Flow checks or "spring checks" provide a tight seal against ghosting and most inadvertent flows ,they can be mounted in any position. They have the disadvantage a fairly high resistance to flow. This can be a disadvantage in some mixing pump situations.
Swing checks should only be mounted horizontally and are prone to ghosting in many applications. They have the advantage of comparatively low resistance."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87K THE MAIN WALL
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
