I need t get
Steve_210
Member Posts: 646
More info on combination 1 and 2 pipe systems. I have all of Dan,s books maybe I,m missing something.
perhaps
Could you post a specific question.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Yes please
more specific questions! One could write a book on the topic...
One might note, though, that there is nothing special about combination systems; the one pipe areas will behave that way, and two pipe areas the way other two pipe systems run...Br. Jamie, osb
I don,t have
A specific question. I just wanted to find some more reading material.
For example we had a job recently which had 1 1 pipe rad on a 2 pipe system we added a return and trap to make it 2 pipe. It would have been alot easier to leave it 1 pipe.
We have no control over pressure or venting as it is an apartment building and I was afraid of spitting vent onto a wood floor. LIABALITY0 -
Burnham Heating Helper
Hi- I'm not a pro, but one of the most useful books I have found for quick reference is the Burnham Heating Helper. It's really handy to check the specs and capacities when you run across odd ball piping which you typically find with mixed one and two pipe systems.
If you don't already have a copy here is the link:
http://pro.usboiler.net/PDF/htghelper.pdf
- Rod0 -
Thanks rod
We have copies and it is a great handbook.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
