I need t get
Steve_210
Steve_210 Member Posts: 647
More info on combination 1 and 2 pipe systems. I have all of Dan,s books maybe I,m missing something.
  • Dave in QCA
    Dave in QCA Member Posts: 1,804
    perhaps
    Could you post a specific question.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    Jamie Hall Member Posts: 26,243
    Yes please
    more specific questions!  One could write a book on the topic...
    One might note, though, that there is nothing special about combination systems; the one pipe areas will behave that way, and two pipe areas the way other two pipe systems run...
  • Steve_210
    I don,t have
    A specific question. I just wanted to find some more reading material.
    For example we had a job recently which had 1 1 pipe rad on a 2 pipe system we added a return and trap to make it 2 pipe. It would have been alot easier to leave it 1 pipe.
    We have no control over pressure or venting as it is an apartment building and I was afraid of spitting vent onto a wood floor. LIABALITY
  • Rod
    Rod Posts: 2,067
    Burnham Heating Helper
    Hi- I'm not a pro, but one of the most useful books I have found for quick reference is the Burnham Heating Helper. It's really handy to check the specs and capacities when you run across odd ball piping which you typically find with mixed one and two pipe systems.
    If you don't already have a copy here is the link:
    http://pro.usboiler.net/PDF/htghelper.pdf
    - Rod
  • Steve_210
    Thanks rod
    We have copies and it is a great handbook.
