Pipe insulated.
cunam
cunam Member Posts: 13
Hello All
As you can see the picture below, the vertical pipe that connect to the main steam vent is not insulated.My question is can I insulate this pipe in order to save the energy?Thanks for your answer.
    Jamie Hall Member Posts: 26,838
    Eh, why not?
    won't save much, but can't hurt.  Assuming the rest of your mains are all insulated first!
  • kcopp
    kcopp Member Posts: 4,630
    Thats your....
    main or at least one of your main vents. It looks small. It should be upsized to a better/ faster vent... Gorton #1.
  • Abracadabra
    vent riser
    don't insulate that 1/2" or 3/4" pipe that connects the vent to the elbow.
