Superstor with carcked shell
Member Posts: 4,328
Has anyone seen this happen to a Superstor? It looks like a layer of cardboard under the shell and the owner is concerned about the fire danger.
Yes
Have seen it before. Is there a thermal expansion tank for the domestic? Once there is a slight crack in the plastic jacket, it takes right off. Either there is a leak behind the insulation, or the tank is flexing a bit. There is no fire danger that i can fathom0 -
No issue
If I remember right the "hole" problem...pun intended was from when the press they used to cut the holes out got dull. It would not make a clean cut and would split from the expansion of the tank. It's just cosmetic and does not pose a danger to anything.0 -
Here's an idea
Assuming that strap had nothing to do with it, how about sending that picture to HTP and see what they have to say?0 -
Same here
My superstor casing is cracked and the crack has been growing.0 -
alot
I have a bunch of those...looks terrible...0 -
I have yet to see one that DIDN'T split....
I think it has to do with either PVC contraction, or the foam expanding. The tank vessel is not compromised.
ME0 -
I've got to ask...
Have you contacted the manufacturer and asked for a replacement? This is obviously a design/manufacturing flaw. I would be more than hesitant to use the product.0 -
Manufacturer
I spoke to HTP technical support this morning who said we can go to our wholesaler and request an insulating jacket from them or we can use a store-bought jacket and send our rep. the bill, up to $100. The insulating jacket would be placed over the vinyl jacket. He said the cause of the tearing is from internal expansion over time, the pressure causing the vinyl covering to fail.
I'm just replacing a Superstor on another job. It started leaking after a few years and the owner decided to replace it with a Vitocell H-300.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Normal
Half of them crack, And they still make them the same way ... Stainless weld leaks , well leaks We build for the short buck in this country , sorry to say ...There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
