radiator vent: do I need it?
rk
Member Posts: 4
I have steam heating system. The radiator in my room doesn't get heated unless I remove the vent completely. Replacing the vent with a new one didn't work. The new vent is adjustable so the issue is not about the opening of the vent. Would removing the vent completely create any problem in the future?
DON'T DO IT
MY MOTHER KNOWS SOMEONE THAT DID JUST THAT AND THE LADY'S NIECE SUFFOCATED TO DEATH. THE STEAM WILL DISPLACE THE AIR THAT IS IN THE ROOM. THERE IS ALSO A SERIOUS RISK OF BURNS.0 -
Yes
As bn says, don't do it. You can try a faster vent, perhaps.
There are many different vents available -- some much faster than others; some adjustable.
But don't take it off. It's there for your safety, as well as to control the system.Br. Jamie, osb
Thanks for the warning!
Is there any other solution? The adjustable vent didn't work. Are there vents with bigger holes than adjustable vent.0 -
Jamie, I guess you answered my question. So there are bigger vents available than the adjustable vent. I just have to find it. May be Home Depot.
Thanks0 -
vents
Which adjustable vent do you have? If its theheattimer varivent then you already have the fastest radiator vent out there. You might need more venting on your steam mains and possibly less venting on your other radiators. You can experiment by shutting the valves on some other radiators and seeing if you get more heat on the problematic radiator.0 -
what temperature is your room?
You indicate that your radiator does not get hot, but perhaps it is getting just little bit of steam? Also, is your room the same temp as the rest of the building? Is it comfortable? If the answers are yes, what is the problem?
Remember, in mild weather radiators rarely get hot, as the boiler usually runs a short period of time and and the radiators will only see a very small amount of steam. As it gets colder outside and the demand for heat increases, the boiler will run longer each time and more of he radiator will warm up. When it gets down to 0, you will probably see the entire radiator get hot and at the point the vent will close.
Adjust the vent according to room temperature and your heating needs, put it back in the radiator. Observe your radiator as the winter season progresses. It will get colder out and you will get to see your radiator heat up completely.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
"heat timer" varivalve
As you suggested, I replaced the vents with "heat timer" varivalve. The radiator now works great. Thank a lot for your help.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
