thermostat wire
ChrisJ
Member Posts: 16,837
This may be a cheesy question but can I use 18AWG copper 2 conductor stranded wire for my thermostat? I know it calls for 18AWG but I always see solid wire on them and don't want to violate code.
Its 2 conductor non shielded in a single black jacket I think black and white colors if it matters. I realize it will work fine, but will it be to code? I will of course tin the ends to keep them from fraying.
Code may vary
from place to place. Of considerably more interest, from a practical point of view, is the overall rating of the wire -- temperature, voltage. Stranded or not stranded probably is not relevant -- but temperature and voltage ratings will be.Br. Jamie, osb
temp rating
rated for 105C looks like it has a UL listing as well type CL2R.
I would think the voltage rating would be irrelevant as its for a 24V system. I'm sure the wire is good for more than 100v.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I do not know codes, but...
for things like wiring thermostats, I would think solid wire to be better than stranded, because it is too easy to let a strand get loose and short out an adjascent terminal. I know it can be done, but not if you are in a hurry.
Stranded wire seems more suited to something that needs to be moved frequently, such as a floor lamp, not something in a wall that moves only during earthquakes and demolitions.0 -
T'stat wire
for regular thermostats ,like you have,can be either.As JDB said ,watch out for loose strands. So strip back the insulation and twist the strands a few times real good . I think the volt rating is 85v or 90v.0 -
strands
Appreciate the responses.
Like I said I'll be sure to tin the ends of the wires so there won't be any loose strands. I want to use it because we have a huge spool of it where I work and the boss doesn't mind me taking 30 feet or so.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
