thermostat wire
ChrisJ
ChrisJ Member Posts: 16,834
This may be a cheesy question but can I use 18AWG copper 2 conductor stranded wire for my thermostat?  I know it calls for 18AWG but I always see solid wire on them and don't want to violate code.
Its 2 conductor non shielded in a single black jacket I think black and white colors if it matters.  I realize it will work fine, but will it be to code?  I will of course tin the ends to keep them from fraying.
    Jamie Hall Member Posts: 26,157
    Code may vary
    from place to place.  Of considerably more interest, from a practical point of view, is the overall rating of the wire -- temperature, voltage.  Stranded or not stranded probably is not relevant -- but temperature and voltage ratings will be.
  • ChrisJ
    edited November 2011
    temp rating
    rated for 105C looks like it has a UL listing as well type CL2R.
    I would think the voltage rating would be irrelevant as its for a 24V system.  I'm sure the wire is good for more than 100v.
  • Jean-David Beyer
    I do not know codes, but...
    for things like wiring thermostats, I would think solid wire to be better than stranded, because it is too easy to let a strand get loose and short out an adjascent terminal. I know it can be done, but not if you are in a hurry.
    Stranded wire seems more suited to something that needs to be moved frequently, such as a floor lamp, not something in a wall that moves only during earthquakes and demolitions.
  • Techman
    Techman Member Posts: 2,143
    T'stat wire
    for regular thermostats ,like you have,can be either.As JDB said ,watch out for loose strands. So strip back the insulation and twist the strands a few times real good . I think the volt rating is 85v or 90v.
  • ChrisJ
    strands
    Appreciate the responses.
    Like I said I'll be sure to tin the ends of the wires so there won't be any loose strands.  I want to use it because we have a huge spool of it where I work and the boss doesn't mind me taking 30 feet or so.
