please identify
This is an interesting forum. I don't know if this is the correct place
to post this but can someone tell me what I have in these photos. It
is about 4 1/2 feet high x 4 feet wide x 7 feet deep. It is in the
building I just bought. I looked for information on US Radiator Corp
and found nothing.
Thanks,
Arnold
and found nothing.
Thanks,
Arnold
It is an old
boiler that probably was used to heat the building. As it looks from your pictures it has not been used in a long time as a heating system. Is there some other means of heat in the building?
If you are thinking of restoring it I would say not the best idea. It would be best to go with a new system from scratch.
What kind of emitters do you have? radiators, convectors etc.0 -
please identify
The boiler in the photos is not hooked up anymore and hasn't been used in many years. I don't know what type of emitters or convectors but there are some tall radiators in the above floors. I don't know what types but will look for names. Someone said the red top may be significant to type of boiler?0 -
Some pictures of
the radiators would help to identify if it was a steam system or hot water.0 -
Steam
It's steam,the upper gauge glass cock is visible as well as the tapping for the missing lower cock. It's worth 16 cents/lb hereTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Steam it is
just spotted the pig tail in the first picture.0 -
My guess..
There's about 1600-2000lbs of cast iron there waiting to get recycled.0 -
RE
Save the gauge!0 -
So,
So, it's cast iron that can go to the scrap yard. Thanks for the i.d. Is there any way to turn it into a wood stove? or a blacksmithy's forge? or something useful? Thanks again0 -
Alternative use....
I have used these cast iron behemoths as a heating radiator before, and they work fantastic. Hook it up to the supply and returns, and install a non electric thermostatic radiator control valve to it, and let the 500 pound radiant gorilla in the corner heat your basement. Clean it up, fix it up, spit polish it, hand paint the raised letters, and even throw an electric light bulb that looks like a flickering flame into the fire box for effect, and it makes a GREAT conversation piece.
If you intend to recycle it through a metal recycler, be prepared to spend at least one day on the end of a sledge hammer, and another carting the pieces out of your house and into the yard, then into the truck.
Re-use is better than recycle...
ME0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
