Aero Burners
richardplace
Member Posts: 10
I am searching for a Fenwal ignition module for an Aero # PCB-220-8 S/N 9511-03243
It is a burner to convert an oil fired boiler to natural gas. The Fenwal # 05-296426-251
I've Googled the information but I am not having any luck. Any help would be much appreciated.
I am not sure
if it is listed as a replacement for that Module but typically any Direct Spark module could replace it.
However why not contact Fenwal for a direct replacement from them. Contact info:
Fenwal Controls
400 Main Street
Ashland, MA 01721
Phone 508-881-2000
I am sure they will be able to help you.0 -
I looked up
Fenwal Control # 05-296426-251 in the Robertshaw Catalog (Robertshaw distributes for Fenwal) the replacement is a Triton Model # 2460D601-201 according to their catalog.
I would however confirm that with Fenwal.0 -
Fenwal Igniter
Tim, Thanks for the info. I had already called Fenwal. They have a replacement but can't ship for 3 weeks. Mounting is critical on this boiler and I haven't found a direct spark igniter that will fit. It's a 1961 boiler with a gas conversion burner. I'll just wait out the 3 weeks. Thanks.0
