Aero Burners
I am searching for a Fenwal ignition module for an Aero # PCB-220-8 S/N 9511-03243
It  is a burner to convert an oil fired boiler to natural gas. The Fenwal # 05-296426-251
I've Googled the information but I am not having any luck. Any help would be much appreciated.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    I am not sure
    if it is listed as a replacement for that Module but typically any Direct Spark module could replace it.
    However why not contact Fenwal for a direct replacement from them. Contact info:
    Fenwal Controls
    400 Main Street
    Ashland, MA 01721
    Phone 508-881-2000
    I am sure they will be able to help you.
  • Tim McElwain
    I looked up
    Fenwal Control # 05-296426-251 in the Robertshaw Catalog (Robertshaw distributes for Fenwal) the replacement is a Triton Model # 2460D601-201 according to their catalog.
    I would however confirm that with Fenwal.
  • richardplace
    richardplace Member Posts: 10
    Fenwal Igniter
    Tim, Thanks for the info. I had already called Fenwal. They have a replacement but can't ship for 3 weeks. Mounting is critical on this boiler and I haven't found a direct spark igniter that will fit. It's a 1961 boiler with a gas conversion burner. I'll just wait out the 3 weeks. Thanks.
