If our community has helped you, please consider making a contribution to support this website.  Thanks!
Weil-McLain GV-4
                    Cruisinfanatic
                    Member Posts: 31
                                  in Gas Heating
                    Bought a new 1013-200 that replaces the 1013-100 boiler control unit for my gv-4.
Am I correct in my understanding that I can just plug it in. I have the taco 007 circulator.
Apparently if I had the upgraded one I would need to use the included cable?
            Do you have
 two circulators one a system circulator and the other a bypass circulator? If so just plug in the harness as it is on the boiler. If not then they sent you a harness with the 1013-200 is that correct?0
 just have 1 circulator. A new harness was included with the control unit. I don't think I need it. Right?0
            If you have just one circulator
 you will not need it. Did you get a small "jumper" with the 1013-200? If so it will need to be plugged into the new unit unless you have a sensor (thermistor) on the return pipe to the boiler, if so then it plugs into the board.0
 nope, just the control and the harness0
            It may
 already be in place on the 1013-200.0
            Boiler Control module
 I also need to replace my control module 1013-100 and have been wondering if the 1013-200 would work. Did you get this control module to work on your Boiler, mind is same as your's with a single pump.0
            Marty it will work
 it is Weil McLains replacement for the 1013-100 and other Integrated Boiler Controls from Weil McLain.0
 Thanks Tim, I thought it would just wanted to hear conformation from someone else.0
            looking for 1013-200
 Hello, I have a Weil-McClain GOLD GV-6 boiler (approx 20 yrs old) I believe the original United Technologies control p/n 1013-100 has become faulty and I would like to know where I can obtain a replacement? It looks like this unit has been replaced by p/n W-M p/n 382-200-448 or UT p/n 1013-200.
 Thanx for any info0
            Module 1013-200
 I was lucky and found my
 Module 1013-200 replacement
 on Ebay a yr or so ago for less than $50. Don't see any for sale right now but keep checking.
 Google it for suppliers0
            F.W. Webb is a
 Weil McLain dealer so if you can find one near you they will be able to get it for you.0
            GV-4:
 If that is a Series 2, they have an upgrade module. You may be looking for an older OEM module. I have a customer with a GV-4 that was going off all the time. A gas provider serviced the gas. When the owner had no heat, they called the gas guy. When they started having no hot water, they started calling me. I finally got PO'ed and changed the control to the upgrade. It hasn't failed once/since.
 I can't imagine getting any good new controls on E-Bay. Do they come with a warranty that you can use?0
            GV-4
 installed upgraded control beginning of summer and hasn't shut off since. At $50 I didn't expect a warranty0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
