Weil-McLain GV-4
Cruisinfanatic
Member Posts: 28
in Gas Heating
Bought a new 1013-200 that replaces the 1013-100 boiler control unit for my gv-4.
Am I correct in my understanding that I can just plug it in. I have the taco 007 circulator.
Apparently if I had the upgraded one I would need to use the included cable?
Do you have
two circulators one a system circulator and the other a bypass circulator? If so just plug in the harness as it is on the boiler. If not then they sent you a harness with the 1013-200 is that correct?0 -
just have 1 circulator. A new harness was included with the control unit. I don't think I need it. Right?0 -
If you have just one circulator
you will not need it. Did you get a small "jumper" with the 1013-200? If so it will need to be plugged into the new unit unless you have a sensor (thermistor) on the return pipe to the boiler, if so then it plugs into the board.0 -
nope, just the control and the harness0 -
It may
already be in place on the 1013-200.0 -
Boiler Control module
I also need to replace my control module 1013-100 and have been wondering if the 1013-200 would work. Did you get this control module to work on your Boiler, mind is same as your's with a single pump.0 -
Marty it will work
it is Weil McLains replacement for the 1013-100 and other Integrated Boiler Controls from Weil McLain.0 -
Thanks Tim, I thought it would just wanted to hear conformation from someone else.0 -
looking for 1013-200
Hello, I have a Weil-McClain GOLD GV-6 boiler (approx 20 yrs old) I believe the original United Technologies control p/n 1013-100 has become faulty and I would like to know where I can obtain a replacement? It looks like this unit has been replaced by p/n W-M p/n 382-200-448 or UT p/n 1013-200.
Thanx for any info0 -
Module 1013-200
I was lucky and found my
Module 1013-200 replacement
on Ebay a yr or so ago for less than $50. Don't see any for sale right now but keep checking.
Google it for suppliers0 -
F.W. Webb is a
Weil McLain dealer so if you can find one near you they will be able to get it for you.0 -
GV-4:
If that is a Series 2, they have an upgrade module. You may be looking for an older OEM module. I have a customer with a GV-4 that was going off all the time. A gas provider serviced the gas. When the owner had no heat, they called the gas guy. When they started having no hot water, they started calling me. I finally got PO'ed and changed the control to the upgrade. It hasn't failed once/since.
I can't imagine getting any good new controls on E-Bay. Do they come with a warranty that you can use?0 -
GV-4
installed upgraded control beginning of summer and hasn't shut off since. At $50 I didn't expect a warranty0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
