gravity feed hot water boiler to be replaced
homeowner2
Member Posts: 8
What does it take to convert my boiler from a gravity 2 pipe hot water system to a forced to pipe water system? I am also relocating it from front of house to back to make some space in basement. What devices should be install along with boiler?
Gravity Conversion
I would suggest the following article which is taken from the "Systems" tab above. Very informative.
Ihttp://www.heatinghelp.com/article/332/Gravity-Hot-Water-Heating/72/Gravity-Hot-Water-Heating-FAQBob Boan
repacing boiler
Thanks for responding. The acticle you suggested was very informative.0
