gravity feed hot water boiler to be replaced
homeowner2
Member Posts: 8
What does it take to convert my boiler from a gravity 2 pipe hot water system to a forced to pipe water system? I am also relocating it from front of house to back to make some space in basement. What devices should be install along with boiler?
Gravity Conversion
I would suggest the following article which is taken from the "Systems" tab above. Very informative.
Ihttp://www.heatinghelp.com/article/332/Gravity-Hot-Water-Heating/72/Gravity-Hot-Water-Heating-FAQBob Boan
repacing boiler
Thanks for responding. The acticle you suggested was very informative.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
