Certified Energy Manager
Tim McElwain
Member Posts: 4,625
Does anyone posting here have this certification? If so what is required to be able to get the certification?
CEM
Here is the link to the site that shows the prerequesites and some of the recommended course materials.
[u][color=#800080]http://www.aeecenter.org/i4a/pages/index.cfm?pageid=3351[/color][/u]
I am currently studying for this but don't plan on taking the test until early 2012. Never to old to keep learning and this is something that will benefit me down the road. I think I will also take the 2-day intensive prior to the test. (There is a 5-day intensive also available)
You will not be surprised to know Brad White has his CEM accredidation.
Best,
Paul0 -
Thanks Paul for
the information. No I am not surprised about Brad as he is one of the best I have run into concerning mechanical issues.
It looks like future requirements for any commercial systems going in will require someone involved with the mechanical side of things to have this certification. I am encouraging my grandson who is an architect to look into it.0 -
Prep is Key
I have the CEM certification and I suggest your grandson do some research at the link provided. It can be a challenging test to those unfamiliar with the required content or an aversion to performing energy calculations. I would suggest taking the 3 or 5-day seminar leading up to the test as you go over everything on the test. You also have to meet certain minimum educational & work experience requirements before becoming eligible to be certified. The work pre-requisite may be difficult to acheive as it requires (IIRC) three years experience in energy-related work.
Having experience with Building Information Modeling (BIM) is huge right now. As an architect - getting the USGBC's LEED Accredited Professional certification is also pretty much a requirement now. I have that certification as well, but the CEM is more applicable to my job (Energy Engineer).0 -
Thanks PS
I appreciate your input and insight. My grandson has a long way to go and a lot to learn so this will be one more thing to add to his agenda. He already owns and operates a Construction and Design company and is working on all his certifications and licensing as he learns the ropes. He is a licensed contractor and architect so to broaden his scope of what he can bid on he needs the CEM I am sure down the road.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
