New Weil-mclain
AFred
Member Posts: 81
Has anyone installed any of those new GV90+?
I think I like them already! They still want P/S piping.
I just want to hear others thoughts.
-Andy
-Andy
They have
a primary pump as well as an injection pump to protect the CI boiler already installed. You can pump through them in certain applications. Why not just use a real condensing boiler?0 -
The GV90+
IS a real condensing boiler. It uses a stainless-steel recuperator to condense, and the main HX is cast-iron.
Trouble is, they do not list any non-PVC venting options in the I&O manual for that unit.All Steamed Up, Inc.
Consulting0 -
I'll redefine "real"
A purpose built modulating/condensing boiler with integral ODR0 -
GV90+ venting
The GV90+ can be vented with PVC. Link below for manual. See pgs 32 and 33 for info.
http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/boilers/gas-boilers/gvplus/gvplus_boiler_manual.pdfTerry O0 -
You are correct Terry
I had not had a chance to retract my AL29$C statement. I read the manual and yes PVC is listed.0 -
The SS venting method
looks like an afterthought in this manual. All of the diagrams show PVC venting- not too encouraging to those of us who are wary of PVC for venting.All Steamed Up, Inc.
Consulting0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
