Homeowner
mik35al
Member Posts: 3
I have to re-set the collector hood cover (collector hood sits on top of the boiler sections assembly, connected to the draft hood, and collects hot temp. gases from combustible chamber) after cleaning the boiler sections.
Where I can buy a high- temp gasket about 1" wide (appr. 5 l. f.)?
Is there other type of high-temp. sealer that can be used for this purpose (Boss
376 red silicon is only up to 500 F)?
Thanks,
Mike
Thanks,
Mike
What kind of Boiler is
this? You can probably get what you are looking for from the local boiler supply company.
You state you are a homeowner, I would not suggest you undertake what you are doing. Do you plan to conduct a combustion test upon completion of your cleaning?
Fossil fuel burning appliances not correctly put back together can make Carbon Monoxide.0 -
Homeowner
Dear Mr. McElwain,
The boiler is Weil-McLain, residential, steam, nat. gas.
The work IS done by the licensed HVAC contractor from the list approved by the boiler Manufacturer.
According to the Manufacturer that gasket material should withstand 700 F.
Unfortunately, "local boiler suppliers" keep in stock stuff only up to 450 F and nobody wanted to order such a small amount (less than 5 l.f.)
So, I decided to help the Contractor to find whether anybody has the leftovers.
Thank you for the fast response.
Mike0 -
Sorry but you did not include that in
your first posting and I was only trying to prevent a homeowner from getting killed with a potentially dangerous area of repair on a boiler.
Try this:
Steve Stultz
Weil McLain Technical Service Supervisor
800-526-6636 Work
sstultz@weil-mclain.com
219-873-0740 FAX
500 Blaine St.
Michigan City, IN 46360-23880 -
Homeowner
Thank you very much Mr. McElwain
Mike0 -
Seal Material
Kaowool good up to 2300 degrees. Available at SiD Harvey 1" X1/4" 300 foot roll Part # 633-90 Kaowool # 9501. A good contractor who services boilers should have it on the truck. You pretty much can't do a lot of boiler service work with out it. Some guys will use the fiberglass rope. I carry both on the truck.0 -
Sealing Bonnet:
If you are dealing with a Weil-McLain SGO boiler, I always use 3/8" Refractory rope on the bonnets and glue them down with Hi-Temp RTV. I slather the bonnet with Never-Seize in hopes that the rope doesn't stick to the bonnet. The rope may be 1/4". It's in the truck and I am not there. I use the same rope to replace the rope door gasket when I clean out the bottom. Mt supplie3r always has it on hand.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
