evaporator
val107d
Member Posts: 2
can a evaporator coil be installed on the return of a counter-flo furnace?
Definitely Not
An evaporator should never be installed on the return side of a furnace. The cooled air will cause condensation on the heat exchanger which will in turn ruin the heat exchanger.Bob Boan
Double Ditto.
Bob is absolutely correct. Evap coils must go into the supply duct work.0
