evaporator
can a evaporator coil be installed on the return of a counter-flo furnace?
  • Ironman
    Ironman Member Posts: 7,927
    Definitely Not
    An evaporator should never be installed on the return side of a furnace. The cooled air will cause condensation on the heat exchanger which will in turn ruin the heat exchanger.
    Bob Boan
  • meplumber
    meplumber Member Posts: 673
    Double Ditto.
    Bob is absolutely correct.  Evap coils must go into the supply duct work.
