Boiler thermostatic by pass valve
Guido
Guido Member Posts: 2
I am working on a snowmelt system, using a Burnham boiler, which uses a Taco by pass valve 595-1 and a thermostat, P/N 80160432. These parts are no longer available. I was wondering if anyone has come up with a solution for replacement of this valve. I am looking at purchasing some by pass valves made by Danfoss, ESBE series. Or instaling a modorized three way bypass valve. The bypass valve are requiered to prevent the condensation of flue gasses in the boiler.
Thanks!
Guido
  • Brad White
    Brad White Member Posts: 2,399
    A bypass circulator
    such as a Taco VS series can also be used to great effectiveness. The setpoint version may be right for you.  Nothing wrong with the ESBE valves and such, just showing another option. I find circulators to be faster-acting and more positive than modulating valves which tend to be slower to respond.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • Guido
    By pass valve
    Thanks for your help. I am not familiar with the use of a by pass circulator, but will do some investigating, keep all options open.
    Thanks!
    Guido
