How Many Have Used
CMadatMe
Member Posts: 3,086
This product. <a href="http://www.cleaningupoil.com/index.php">http://www.cleaningupoil.com/index.php</a> I attend at meeting last night and these product was demonstrated. Has anyone had any experience with it and does it work as advertised? Thanx..
Chris,
We have been using this product with much success. The only downside is when you use the spray bottels as applicators for Step 1 & Step 2, if you dont clean the sprayer after each use you'll need to replace the spray bottel or at least the sprayer. If you just pour the product out of a bottel then you're potentially using more product than what you need.There was an error rendering this rich post.
Thanks
Good points. thanksThere was an error rendering this rich post.
Chris,
You're very welcome.There was an error rendering this rich post.
- 167 Indoor-Air Quality
