How Many Have Used
CMadatMe
Member Posts: 3,086
This product. <a href="http://www.cleaningupoil.com/index.php">http://www.cleaningupoil.com/index.php</a> I attend at meeting last night and these product was demonstrated. Has anyone had any experience with it and does it work as advertised? Thanx..
"The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
Chris,
We have been using this product with much success. The only downside is when you use the spray bottels as applicators for Step 1 & Step 2, if you dont clean the sprayer after each use you'll need to replace the spray bottel or at least the sprayer. If you just pour the product out of a bottel then you're potentially using more product than what you need.0 -
Thanks
Good points. thanks"The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
