Trane electronic air cleaner help please
Dave_134
Member Posts: 5
in Gas Heating
Hi,
I have two 1993 vintage Trane BEF140,200c air cleaners, power supplies dies.
I pulled them and changed the bridge rectifier and found a transistor bad on each one, (each has 2), I combined the good ones, still no good.
Power supplies are obsolete or I woudl buy them.
I was hoping to find a universal power supply i could retrofit to may units and eleminate all the duct work hassle.
Any experience with this?
Thank you.
Thank you.
EAC
pull those pieces of junk out and install cartridge filter of appropriate size0 -
more info on your opinion
Hi, I considered this,
I take it u do not like these. Are they less effective than the are sold to be? new ones any better? how much experience have u had with these?
If I do a 16 x 25 x 4 or 5 filter, what merve would be ok, yet not create excess back pressure?
Thanks0 -
You will have less resistance
with a standard filter than with an EAC. Do you have anyone in the house with breathing issues? If not the standard filters are fine just check/change them every month during the heating season.
If you must replace the EAC do so I am just not a big fan of EAC's.0 -
good stuff!
Hi, no real medical reasons, I noticed a while ago both units were dead, I assume did late last year and I never noticed, so the only filtration I have had was the 1/4" metal mesh filters.
We noticed the house was dusty, or at least seemed so, that's when i found the two dead players on the EAC.
Now I dread the ductwork dis assembly to retrofit new ones so i was going down the repair route. This is why the thick filter plan seemed like a good option I was considering.
Dave0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
