Steam Pipe expansion
RGM
RGM Member Posts: 1
How much would a 1" diameter, 10 foot long iron steam pipe expand from room temperature to 212 degrees?
  • crash2009
    crash2009 Member Posts: 1,478
    How accurate
    of an answer do you need?  Off the cuff, I would say "about one half inch"  If you need something more accurate than that, you need to provide more parameters.  Research: "linear thermal expansion of various pipes"
    http://www.engineeringtoolbox.com/thermal-expansion-pipes-d_283.html
  • BobC
    BobC Member Posts: 5,566
    at least 1/4"
    i don't know exactlyhow far that pipe will expand but I can tell you that a 2" steam main that circles my chimney (about 12 ft long) expands about 1/4" and perhaps a bit more. When cold, the main vent is touching a cold water pipe but when it's full of steam that 2" iron pipe is 1/4" away from the vent.
    Bob
    3PSI gauge
  • Brad White
    Brad White Member Posts: 2,399
    From 70 to 212 in 60 seconds....
    About 1/8th of an inch.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
