Steam Pipe expansion
RGM
Member Posts: 1
How much would a 1" diameter, 10 foot long iron steam pipe expand from room temperature to 212 degrees?
How accurate
of an answer do you need? Off the cuff, I would say "about one half inch" If you need something more accurate than that, you need to provide more parameters. Research: "linear thermal expansion of various pipes"
http://www.engineeringtoolbox.com/thermal-expansion-pipes-d_283.html
at least 1/4"
i don't know exactlyhow far that pipe will expand but I can tell you that a 2" steam main that circles my chimney (about 12 ft long) expands about 1/4" and perhaps a bit more. When cold, the main vent is touching a cold water pipe but when it's full of steam that 2" iron pipe is 1/4" away from the vent.
3PSI gauge0 -
From 70 to 212 in 60 seconds....
About 1/8th of an inch."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 120 Geothermal
- 394 Solar
