Furnace Not Working Sudenly.
ndnmaster096
ndnmaster096 Member Posts: 1
My furnace stopped working yesterday but im not sure why.
It is an American Standard Warm Air Auto Pilot Furnace.
The Power Is On and everything is connected properly.
The LED Light Inside The furnace blinks 3 times and then is steadily RED.
We checked the thermostat everything is fine.
We also tried turning off the braker and turning it on with no help.
Yesterday Night it was running fine, today because of some rain which happened over night the filter was a little bit wet so i took it out to dry , but the problem still consisted even when the filter was there.
Anyone have any suggestions?
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    edited March 2011
    What is the make
    of the board with the blinking lights and the model number of that board? With that information I can begin to make a diagnosis. When you say it is an "auto" pilot do you mean spark ignition?
    If that board got wet that could be a problem. Do you have flooding?
  • sasman
    sasman Member Posts: 32
    3 blinks
    go ahead and make the call to your service tech, he'll know how to repair your furnace
  • John Mills_5
    John Mills_5 Member Posts: 952
    Why is the filter wet?
    Water in a furnace isn't good. 3 blinks is pressure switch. Could be getting water in it too. Steady red is bad board. Get a good tech out there and tell him the codes you saw. And figure out why things are getting wet!
  • Techman
    Techman Member Posts: 2,143
    blink,blink,blink
    Is this a condensing furnace?Is the filter wet from rain or backed up flue condensate?
