How do you pump refrigerant into condensor for transport to another location?
Nemo
Member Posts: 1
I bought an Armana central air system from a guy whose house was in the process of being foreclosed. Now I have to take it out of his place and move it elsewhere. I was hoping to simply pump the refrigerant into the condensor, backseat it, and then move it. Is this possible? If so, how?
PumpDown
That is what it is called.Do you have the Federal E.P.A. Certificate for refrigerants?You might need a reclaim tank,recovery pump ,refrigerant gauge mainfold,Ampmeter,goggles/glasses and an understanding of how easy it is to kill a good compressor by trying to cram 5lbs of freon into a 3lb bag ,I mean condensor coil.Or 50lbs into a 30lb condensor/reciever. There are not many of my customers units that will PumpDown into the cond unit.Do you feel lucky?0 -
I Would 2nd What Techman Says
Especially if it's one of the newer 13 seer units that has 1/4 in tubing in the condenser coil.Bob Boan
It's not a DIY job
What about the legal implications of removing property from a home in foreclosure?0 -
stealing
i can foresee you and whom ever you bought that unit from being in a court room0 -
a little help.
you might be able to pump some of it down. but those valves that come with the unit are not really usable valves. they may hold, they may not. if i were you, i would use any of the old gas. you never know what happened in that system. by the way, you're not legally allowed to do what you are trying to do. the only way its legal is if you were the owner of both homes.0
- 123 Chimneys & Flues
