To prime or not to prime ?
Irv
Member Posts: 95
Prime the pigtail with water, or let it develop on it's own ?
Thanks....
Thanks....
Prime it...
depending on where it's mounted, it can take anywhere from a few cycles to weeks to fill on its own.Br. Jamie, osb
Prime
Yes.
Our standard detail includes a tee with an up-turned street elbow and valve for the purpose although a plug and funnel would work as well. Cheap insurance to protect your essential instrumentation, IMHO."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 84.3K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 795 Plumbing
- 5.4K Radiant Heating
- 371 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
