economizer???
Paul S_3
Paul S_3 Member Posts: 1,291
hey everyone. im having trouble with a york packaged unit with a w7212 honeywell economizer. i have been to this job twice for no heat. upon arrival i found the heat running normal, but also find the economizer in the fully open position. i disconnect the plug and reconnect it and it closes, then come back to find it open. if im not mistaken i thought the economizer only opens on a call for a/c, depending on the enthalpy control am i missing something???
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    The best thing
    for you to do is go to www.customer.honeywell.com and plug in the W 7212 and there is a wealth of information there on how it can be used and also how to set up and troubleshoot. Just too much information to post here.
    Hope that helps.
  • RobbieDo
    RobbieDo Member Posts: 130
    Economizer
    A economizer in commercial buildings is used in the winter for fresh air return. It isn't setup right, have had these issues before. Contact Honeywell, there very helpful.
  • RobbieDo
    Economizer
