economizer???
Paul S_3
Member Posts: 1,291
in Gas Heating
hey everyone. im having trouble with a york packaged unit with a w7212 honeywell economizer. i have been to this job twice for no heat. upon arrival i found the heat running normal, but also find the economizer in the fully open position. i disconnect the plug and reconnect it and it closes, then come back to find it open. if im not mistaken i thought the economizer only opens on a call for a/c, depending on the enthalpy control am i missing something???
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
The best thing
for you to do is go to www.customer.honeywell.com and plug in the W 7212 and there is a wealth of information there on how it can be used and also how to set up and troubleshoot. Just too much information to post here.
Hope that helps.0 -
Economizer
A economizer in commercial buildings is used in the winter for fresh air return. It isn't setup right, have had these issues before. Contact Honeywell, there very helpful.There was an error rendering this rich post.
Economizer
