NOISE ON PIPES
GREENMAN
GREENMAN Member Posts: 25
HELLO EVERYONE HOPE YOU ALL HAD A NICE DAY.
WELL GOT A CALL FOR NOISE ON PIPES ON A GAS FIRE HYDRONIC BOILER, THE EXPANSION TANK THAT WAS THERE WAS VERY OLD AND BANGING LIKE CRAZY SO I REPLACE IT AND ALSO BLEED THE BOILER AND ALL WAS GOOD FOR ABOUT 3 WEEKS UNTIL I GOT THE CALL BACK THEY SAY THE NOISE IS A LITTLE MORE EVERY NIGHT THEY ALSO SAY IT ONLY HAPPENS AT NIGHT . ANY IDEAS ?
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    What is the system
    pressure? Do they have zone valves or circulators?
    You said you bleed the system, was there air in the systems? Typically bleeding is not necessary on a system which has the PRV working correctly and has not been opened for any service.
    Any idea were the noise is coming from, piping, boiler etc?
