NOISE ON PIPES
HELLO EVERYONE HOPE YOU ALL HAD A NICE DAY.
WELL GOT A CALL FOR NOISE ON PIPES ON A GAS FIRE HYDRONIC BOILER, THE EXPANSION TANK THAT WAS THERE WAS VERY OLD AND BANGING LIKE CRAZY SO I REPLACE IT AND ALSO BLEED THE BOILER AND ALL WAS GOOD FOR ABOUT 3 WEEKS UNTIL I GOT THE CALL BACK THEY SAY THE NOISE IS A LITTLE MORE EVERY NIGHT THEY ALSO SAY IT ONLY HAPPENS AT NIGHT . ANY IDEAS ?
  • What is the system
    pressure? Do they have zone valves or circulators?
    You said you bleed the system, was there air in the systems? Typically bleeding is not necessary on a system which has the PRV working correctly and has not been opened for any service.
    Any idea were the noise is coming from, piping, boiler etc?
