Boiler not heating up enough...!
AMAC
Member Posts: 1
in Gas Heating
Old Hydrotherm HC145 boiler is not heating up as well as it should. The water temp is only getting to 120-130 degrees. I have had it cleaned but I don't think it is getting enough oxygen. I just had it cleaned and the chimney is clear. Any Ideas?? Thanks!2
Do you get your
domestic hot water from the boiler?
What makes you think a lack of oxygen would cause you to not have enough heat?
What is the limit on the boiler set to?
Do you have baseboard heat or radiators?0 -
Inlet gas pressure?There was an error rendering this rich post.
- 167 Indoor-Air Quality
