Boiler not heating up enough...!
AMAC
AMAC Member Posts: 1
Old Hydrotherm HC145 boiler is not heating up as well as it should.   The water temp is only getting to 120-130 degrees.   I have had it cleaned but I don't think it is getting enough oxygen.  I just had it cleaned and the chimney is clear.   Any Ideas??   Thanks!2
  • Tim McElwain
    Tim McElwain Member Posts: 4,655
    Do you get your
    domestic hot water from the boiler?
    What makes you think a lack of oxygen would cause you to not have enough heat?
    What is the limit on the boiler set to?
    Do you have baseboard heat or radiators?
  • DanCanDo
    DanCanDo Member Posts: 15
    Inlet gas pressure?
