Exhaust Cleanrance
We are going to install a gas fired forced air system in my office.  We want to direct the exhaust to the exterior. The office is on the ground floor on a corner of an existing building. Above are numerous floors of apartments.  Where can i find the exhaust clearances from the side walk and windows terminating out a wall? The building is in the Bronx, N.Y.  Thanks
  • Ironman
    Ironman Member Posts: 7,903
    Manufacturer's Installation Instructions..
    Are the place to look. Every code that I'm familiar with defers to them.
    Bob Boan
  • DanCanDo
    DanCanDo Member Posts: 15
    Be Careful!
    Direct Vent vs. Mechanical Vent mean two different clearances.  Direct Vent (2) Pipe allows for 1ft away from windows, door, etc.  Single Pipe Direct Vent is now up to 3 or 4 ft.  Inside corners also present a unique concern in and of itself.  I can go on and on about fresh air intake concerns as well.  I agree with a previous poster, check the install instructions, but New York has some pretty stringent guidelines.  Local Codes take precedence.
