radiator question
HenryT
HenryT Member Posts: 128
Hi all. Can a two pipe steam radiator be used for a single pipe steam system? or vice versa?
Thanks
    Jamie Hall Member Posts: 26,776
    Yes...
    with some cautions.  First, to go from two pipe to one pipe you will need to drill and tap for a vent.  Many (but not all) radiators have a provision for that, in the form of a pad about halfway down one or both of the end sections.  Some even have a pre-drilled hole, filled with a plug.  Which may be an unholy bear to remove if the radiator is old.
    To go the other way, you will need to add the appropriate return bushing, taking out the plug which is at the bottom.  Which, again, if the radiator is old can be an unholy bear to remove...
  • HenryT
    Thanks Jamie
    I am doing some reading where some two pipes radiators are connected across the top.
    now assuming a radiator is connected across the top (see picture),  can this be used as a single pipe steam assuming I plug the top supply valve (assuming its a 2 pipe radiator) and add a vent in the middle of the radiator opposite the supply valve?
    Thanks!!
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Two pipe and cast iron water radiators
    can be used on one pipe. Steam only radiators( those not connected across the top) can only be used on steam, one pipe or two pipe.
    cell # 413-841-6726
  • HenryT
    Thanks Charlie
    Thanks ALL!
