wall is vibrating when heat is on
Jackman
Jackman Member Posts: 1
  Everytime the heat kicks on there is this loud vibrating noise coming from one of the walls in our bedroom that lasts about 2 minutes.  Our furnace is in the garage, the bedroom is above the garage.  When I step on  certain part of the floor near the wall or press my hand up on the wall the vibrating stops.  This just started a few days ago.  What is going on?  Thanks.
  • GREENMAN
    GREENMAN Member Posts: 25
    WALL IS VIBRATING
    IT SOUNDS LIKE SOMETHING CAME LOOSE CHECK THE PIPE CLAMPS IF YOU CAN SEE THEM IN YOUR GARAGE
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Get a pro to check
    the furnace right away. The fact that you sleep above the area were the furnace is located is dangerous due to the possibility of Carbon Monoxide fumes from the furnace entering your sleeping area. Make sure the Pro you call does a combustion analysis on you r furnace and also checks for a cracked heat exchanger
    Do you have a Carbon Monoxide detector in your bedroom? If you do not I would get one right away.
