wall is vibrating when heat is on
Jackman
Member Posts: 1
in Gas Heating
Everytime the heat kicks on there is this loud vibrating noise coming from one of the walls in our bedroom that lasts about 2 minutes. Our furnace is in the garage, the bedroom is above the garage. When I step on certain part of the floor near the wall or press my hand up on the wall the vibrating stops. This just started a few days ago. What is going on? Thanks.
WALL IS VIBRATING
IT SOUNDS LIKE SOMETHING CAME LOOSE CHECK THE PIPE CLAMPS IF YOU CAN SEE THEM IN YOUR GARAGE0 -
Get a pro to check
the furnace right away. The fact that you sleep above the area were the furnace is located is dangerous due to the possibility of Carbon Monoxide fumes from the furnace entering your sleeping area. Make sure the Pro you call does a combustion analysis on you r furnace and also checks for a cracked heat exchanger
Do you have a Carbon Monoxide detector in your bedroom? If you do not I would get one right away.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 987 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
