Base Ray baseboard parts?
Waterhog
Waterhog Member Posts: 1
Working on repairing some leaking Base Ray cast iron baseboard and was wonder where to get parts. The leak is coming from a connection where two sections are joined. Any help would be appreciated. Thanks!
  • billtwocase
    billtwocase Member Posts: 2,384
    You can still get push nipples
    Did the house freeze at one time, or baseboard support is lacking? These usually don't just leak. It can be fixed, if it is not cracked.
  • Steve_210
    Steve_210 Member Posts: 664
    any
    decent supply house should have them, you will also need the tool to pull them together
  • Ironman
    Ironman Member Posts: 7,859
    Base Ray
    Try here:    http://www.governaleindustries.com/
                                          or
                     http://www.usboiler.burnham.com/
    Bob Boan
