Base Ray baseboard parts?
Working on repairing some leaking Base Ray cast iron baseboard and was wonder where to get parts. The leak is coming from a connection where two sections are joined. Any help would be appreciated. Thanks!
You can still get push nipples
Did the house freeze at one time, or baseboard support is lacking? These usually don't just leak. It can be fixed, if it is not cracked.0 -
any
decent supply house should have them, you will also need the tool to pull them together0 -
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
