thermal hydronic technician
solarguitarguy
Member Posts: 1
Pick-up job again, found the tubing tacked up to the joists instead of to the subfloor with heat transfer plates. Is it worth unfastening the pex and stapling
what I can to the subfloor? Some say line the TVM horizontally to make an air space in the joist, but to me it seems a wrong way of doing it. Any thoughts?
Plates
It needs to be attached to the floor with heat transfer plates and then properly insulated. Your loosing at least 30 % in efficiency and running higher water temps than necessary.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
