Humidification in space pak air handler & tubing?
Tdlsdc
Tdlsdc Member Posts: 4
I've got a unico space pak type ac air handler in an insulated attic and I'm wondering if I can add a steam heat unit to the air handler and run it in the winter for humidification and some air filtering? My hvac contractor says yes. Should I be concerned about mold building up in the ridged high velocity tube ductwork? Located in Chicago area
  • Ironman
    Ironman Member Posts: 7,903
    Not Sure About That
    I'm not sure if the Honeywell "TrueSteam" can overcome the high static pressure of a SpacePak system. I'd call their support line and ask. I don't think mold is an issue.
    Bob Boan
