Humidification in space pak air handler & tubing?
Tdlsdc
Member Posts: 4
I've got a unico space pak type ac air handler in an insulated attic and I'm wondering if I can add a steam heat unit to the air handler and run it in the winter for humidification and some air filtering? My hvac contractor says yes. Should I be concerned about mold building up in the ridged high velocity tube ductwork? Located in Chicago area
Not Sure About That
I'm not sure if the Honeywell "TrueSteam" can overcome the high static pressure of a SpacePak system. I'd call their support line and ask. I don't think mold is an issue.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 120 Geothermal
- 394 Solar
