Air Volume, pipes and radiators...
drtom
Member Posts: 31
What is the formula to determine the volume of air that has to move out of my pipes and radiators? I have the PDF file Balancing Steam Sytems, so I have a basic instruction. What does EDR mean?
I am not a professional, simply a home owner, so I do not have Dan's workbook from Dead Men's Steam School. I have two different types of radiators (pictured below). The first type comes in three sizes, and the second type is unique in my system.
<a href="http://img408.imageshack.us/i/r0701.jpg/"><img src="http://img408.imageshack.us/img408/3918/r0701.th.jpg" width="113" height="150" alt="" /></a>
Type one, small.
<a href="http://img338.imageshack.us/i/r020.jpg/"><img src="http://img338.imageshack.us/img338/5903/r020.th.jpg" width="113" height="150" alt="" /></a>
Type one, large.
<a href="http://img526.imageshack.us/i/r06m.jpg/"><img src="http://img526.imageshack.us/img526/1271/r06m.th.jpg" alt="" /></a>
Type two.
Type one, small.
Type one, large.
Type two.
rad volume
it's unusual to have vents on those rads with 2 pipes. are you sure they should be there?
that looks like a very low pressure vapor system, whose flow of incoming steam is carefully valved so that only the amount which can be condensed is allowed in. i would think that all the venting would be handled in the returns.
nice floors!--nbc0 -
see your other thread...
it is a little unusual to see vents on the radiators on a two pipe system, but this looks like one of the very old systems, which did have vents -- and no traps. Should run on a maximum of 1 to 2 psi.
EDR is the effective direct radiating area of a radiator -- there are references on this site for it.
You might also pick up the three books in "A Steamy Deal", from the shop on this site -- then although you don't have Dan's workbooks, you'll be able to get a pretty good idea as to what is going on.
Please refer to my post on your other thread for more...Br. Jamie, osb
EDRs
It looks like the only way to calculate EDRs is with a $25.00 book. Is there another way? As a home owner, I want to get the proper vents, but I would hate to buy the EDR book and then never use it again.
Does anyone on here have the book and perhaps willing to look up my radiators?There was an error rendering this rich post.
Type One is a "Column" radiator
and the number of vertical members in each section determines whether it's one-column, two-column, three-column etc.
Type two is a "small-tube" radiator. The same vertical member rule applies here- but on this one it's 3-small-tube, 5-small-tube, etc.
If you're not sure what you're looking at, take pics of each from one end. Then post them and we'll tell you what you have. Also include the height of each.All Steamed Up, Inc.
Consulting0
- 120 Geothermal
