Air Volume, pipes and radiators...
drtom
drtom Member Posts: 31
What is the formula to determine the volume of air that has to move out of my pipes and radiators? I have the PDF file Balancing Steam Sytems, so I have a basic instruction. What does EDR mean?
I am not a professional, simply a home owner, so I do not have Dan's workbook from Dead Men's Steam School. I have two different types of radiators (pictured below). The first type comes in three sizes, and the second type is unique in my system.
<a href="http://img408.imageshack.us/i/r0701.jpg/"><img src="http://img408.imageshack.us/img408/3918/r0701.th.jpg" width="113" height="150" alt="" /></a>
Type one, small.
<a href="http://img338.imageshack.us/i/r020.jpg/"><img src="http://img338.imageshack.us/img338/5903/r020.th.jpg" width="113" height="150" alt="" /></a>
Type one, large.
<a href="http://img526.imageshack.us/i/r06m.jpg/"><img src="http://img526.imageshack.us/img526/1271/r06m.th.jpg" alt="" /></a>
Type two.
  • rad volume
    it's unusual to have vents on those rads with 2 pipes. are you sure they should be there?
    that looks like a very low pressure vapor system, whose flow of incoming steam  is carefully valved so that only the amount which can be condensed is allowed in. i would think that all the venting would be handled in the returns.
    nice floors!--nbc
    Jamie Hall Member Posts: 27,379
    see your other thread...
    it is a little unusual to see vents on the radiators on a two pipe system, but this looks like one of the very old systems, which did have vents -- and no traps.  Should run on a maximum of 1 to 2 psi.
    EDR is the effective direct radiating area of a radiator -- there are references on this site for it.
    You might also pick up the three books in "A Steamy Deal", from the shop on this site -- then although you don't have Dan's workbooks, you'll be able to get a pretty good idea as to what is going on.
    Please refer to my post on your other thread for more...
  • drtom
    edited December 2010
    EDRs
    It looks like the only way to calculate EDRs is with a $25.00 book. Is there another way? As a home owner, I want to get the proper vents, but I would hate to buy the EDR book and then never use it again.
    Does anyone on here have the book and perhaps willing to look up my radiators?
  • Rod
    Rod Posts: 2,067
    Work Sheet
    Hi-  Attached is a work sheet that might be of help to you
    - Rod
    Steamhead Member Posts: 18,508
    Type One is a "Column" radiator
    and the number of vertical members in each section determines whether it's one-column, two-column, three-column etc.
    Type two is a "small-tube" radiator. The same vertical member rule applies here- but on this one it's 3-small-tube, 5-small-tube, etc.
    If you're not sure what you're looking at, take pics of each from one end. Then post them and we'll tell you what you have. Also include the height of each.
    Consulting
